It is possible to change out the seat motors?  If so has anyone performed this?  The motor that controls the front part of the seat is locked, the rear will still rise and lower but when the front switch is operated the seat doesn't move it just makes a sound.
If you take the seat out you there is a delay time after switching off the ignition to avoid detonation of the air bag.  There is a set procedure.
