My driver's side lumbar support doesn't inflate the bladder. I can hear the compressor work, so my assumption is that either a tube is broker or the bladder is toast. How can I remove the bladder?
As I recall the center section just pulls down once you pry the top plastic pieces back.
Due to the age of the car the side plastic clips will likely break.
Thanks Loren!
I was afraid that there are plastic clips. And you are right, they will probably break. I am not sure the clips are available for purchase. I may just leave it alone.
