I have pass front turn signal inop, I have replaced bulb with 2 new ones and even replace headlamp wiring harness but still inop?  Any other fixes or things to check ?
I had this same problem. turned out the actual fitting inside the lamp broke away from the lamp housing if that makes sense. I guess I turned it too hard and the bulb fitting - a bayonet like mount - broke away so that the socket wasn't making contact. the fix? - a used headlamp @ $450.00. you can try to disassemble the lamps & then hot glue or crazy glue the socket in place but that's hit or miss
