Hi Loren, been generating this code on my 2006 V6 Cayenne. Where is this pump located? Any relay or fuse Incan check?
Sent from my iPhone using Tapatalk
P0492 Secondary air injection system, bank 2 - below limit
Possible fault cause:
• Fuse F4 faulty
• Open circuit to secondary air injection pump
• Short circuit to ground in the lead to secondary air injection pump
• Secondary air injection pump relay mechanically faulty
• Secondary air valve sluggish
• Secondary air injection pump (air cleaner) blocked
• Air hose to secondary air injection pump slipped off or crushed
• Secondary air injection pump faulty / stuck
I know the turbo has them on top of the motor. And I search my V6 an saw something that looks like the pump under the passenger headlight. Just want to confirm. Also I don't have the location of the relay search near the brake fluid reservoir but they are a few dont know which one belongs to the pump. Thanks again!!
