Car was fine just started it up and all this noise. There are no check engine lights at all . It also makes sewing machine noise when gas pedal is depressed. If anyone can listen and tell that be great.
IMG_4518.mov
What happens if you give some gas?
Mine sounded like that when i had a vacuum leak on the intake manifold.
If i gave some gas the Engine hardly revved.
The first thing i would test would be to take of the oil cap.
If it get worse, then that part of the vacuum is Ok, if it stays the same then you have to narrow it down.
If i remember correct the oil cap thing points to the AOS
