First post here, I'm Lewy from Wolverhampton in the UK. Hi!
I'm having some problems removing my faulty unit. The screw / bolt which retains the unit just turns a full 270 degrees without doing anything whereas the other side only turns 90 degrees and releases the unit no issues.
I've tried (carefully) turning the screw at small intervalls and attempting to prize out the unit but something's gotta hold of it and it will not budge.
Looks like I need to get at it from underneath? Where would you guys start? Is it accessible from removing the bumper?
Ant help or tips would be very well received. Thanks in advance.
Lewy
Sent from my SM-G925F using Tapatalk
You can also remove the air filter box and get behind the light from there. Not difficult to remove and makes a lot of space.
Edited by lewisweller
Thanks for your help guys, will give it a whirl and post back ;)
