The clamping straps have probably lost their tension, remove the water hose and clean up all residues, replace the clamping straps by new ones, preferably by specimens with a tension capability for screw driver or key.
Hi Loren hope you are fine, any help with the part number for the part the expansion tank hose attach to?
Sent from my iPhone using Tapatalk
I agree with RFM that you may likely only need new hose clamps. Those old spring type do not re-use well.
Use the new (stainless steel) spring type hose clamps.
999 512 656 09 Hose clamp 25 x 12 -- US MSRP $2.40 - 2 required
999 512 660 09 Hose clamp 29 x 12 -- US MSRP $2.40 - 2 required
999 512 683 09 Hose clamp 23 x 12 -- US MSRP $2.40 - 1 required
If you really need the hose then it is:
948 106 050 01 Return line hose - US MSRP $51.44
Thanks a lot Loren one last question what is the part number of the plastic part with screws the hose attach to?(motor)
