Fuel Sender Unit Replacement Help Needed
2002... was in the tag line.  Got it off finally.  That connection is just very, very snug.  The plastic buttons were depressed enough.  I just pushed down the connector after I felt it budge a bit. What a pain.
Everything works after a 10 mile test drive.  I put 1/2 tank of gas in and it seems to register properly.  I will fill it up in a few days and drive it till it goes red to make sure everything registers properly.  Hoping I don't need it recalibrated.
BTW I was able to use a loaner OEM Fuel Pump Replacement Kit PN 27160 I got from Autozone.  Made removing and replacing the large ring quite easy and, in the end, won't cost me anything after I return it.
