After my 1999 996 has been sitting for several hours, I hear the typical sound of a chain tensioner not doing its job upon starting, probably for no more than 5 seconds, and then the engine is perfectly quiet.  So I am replacing the tensioners one at at ime, starting with the one that is on the bottom of the engine facing up (I think it is for cylinders 1 thru 3 but not sure), because it makes sense that gravity would effect it the most of the three.  If my noise goes away, I will probably leave the others be, if not, then I will replace the one form the crank to the IMS.  In reading numerous forums, I get that if I am replacing the IMS bearing,  I need make sure the engine is at TDC, and even have the camshafts locked.  But do I need to do both for just changing the tensioners one at a time?
Thank!
Will locking the crank at TDC be sufficient? I have seen several articles suggesting that would be fine for only replacing the tensioners.
