Hi I have tried the normal channels for a radio code, not having much luck,
Forums seem to suggest it's dealer job? anyone point me in a cheaper direction?
its a PCM radio unit.
Didn't read the Lost Radio Code FAQ?
" Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC. "
