First of all, the keys are not programmed, the car is programmed to accept the keys.  This requires the use of a PST II or PIWIS on the car in question.  You will also need the factory code tags that should have come with the keys.
Ok thanks, I don't have the original factory tags ?
All of my keys went off and I didn't have the factory tags, in the end had to bite the bullet and go to the dealers. They charged me around £150 pounds per key and replaced the top key fob with brand new and put in the old blades
