At 130K on the odometer, a bearing in the Tiptronic in my 02 C2 is failing. (My Indy put a stethoscope on it to verify)
I don’t live near a city that might have expertise on repairing these units so I’m thinking to replace it.
Because the later Tips are so reliable, there’s many used units on the market for fraction of the cost of a new one. I wondering if there’s pitfalls I should be aware of in purchasing a used Tip. Like, will a unit from a 04 model plug and play in my 02? Any insight would be much appreciated.
You need to be aware that the later Tips use different electronics to control them, so to be safe, you should stay as close to the same year as possible.
