Got a new to me 2010 997.2 Carerra S.  This is my first Porsche having owned a series of BMWs.
I watched a number of DIYs on the oil change and it seemed to go off without a hitch.
I warmed up the engine prior and let it drain for about 3 hours while I attended to other things. I changed the filter and put in 10qts of oil.
Now the oil level light says it is over full. I guess that is ok as it was eating about a quart a month which seems normal to a BMW owner.  I figured it would drop over a few weeks but it hasn't.
Now about once every day or three since the oil change it asks me to measure the oil level.  Should I be concerned? It seems weird that the proper amount of oil would over top the gauge.
It's never a good idea to overfill the engine.
Unless I'm mistaken, with a filter change, 10 quarts is an overfill of one quart. I'd drain that and then see where you stand.
Expand
Yes, you should be concerned.  Overfilled enough, you can overwhelm the AOS and inhale liquid oil into a cylinder, which will kill your engine.  Drain some of the oil out, and adjust it to the correct level while you still have that option.
