Hi there, my door speakers (non - Bose) are shot. Does anyone know of a direct bolt in replacement? Or at least the size I will need - diameter and maximum depth? Thank you
The door speakers are a standard 5.25" (13cm) unit, however it's the depth you've got to worry about (can't remember off hand), you might need to do a little cutting of the plastic surround do get it mounted. I needed to do this when fitting an Infinity unit.
Damian
Damian
call Rod Birch
www.caraudioinnovations.com specializing in audio upgrades for the Porsche 911 "time spent with a customer is time invested in a friendship" 1-800-892-6430
Damian
call Rod Birch
I replaced mine with Quart 5.25 subs, they fit the facory hole. Slightly longer screws though. A bit pricey but sound good. Search internet for best price. Hope you find what you are looking for.
jorge
Damian
call Rod Birch
jorge
Jorge, did you run the 5.25 Quarts with the standard amp or did you put in a new amp to drive them? If you put in a new amp I assume you also put in a new head unit. Did the new subs make a difference?
jorge
I used the standard amp, i have thought about an aftermarket unit, i haven't got around to it. The subs did make a difference. My stock units sounded ratty. Also i installed a Becker Monza MP3 unit.
jorge
