Need a OBO II analyzer tool so I can diaginois my Check engine light. Where can I purchase this tool and for how much? - Thanks
Most regular auto parts stores sell handheld units for about $100. I bought this one from Kragen. It works well for Porsche, but of course does not have the full capability of the factory system test tool.
The one I use with my laptop is reviewed here.
Loren, I saw the review but did not see the tool itself. Do you have a model number and/or purchase place?
This one is not a tool per se - it is software and a cable. You load the software into a laptop computer and then plug the cable into both the laptop and the OBD II port on the car.
Where can I order the cable and the software?
www.obd-2.com
Looks like a good set up.
So it's call Randy in Chicago? .......I guess e-commerce hasn't rocked 'Midtex Automotive' yet :D
www.obd-2.com
Wow - I might just not be getting it. I go to that site and do not see where I can order or from where. I understand that there is software involved but what cable? Sorry for the stupid questions but I am just not getting it for some reason. :help:
www.obd-2.com
Never mind - I got it - Thanks for the help.
It's a hoaky site but all the info is there, inc a pic of the ISO version connector..............select 'Car Code' there......or if you are already on the "OBDII Automotive Scan Tool and Virtual Dashboard site, then scan down to Technical specs. and pictures of routers, connectors and cable
Mike,
I have the cable/laptop setup that Loren is refering too but it would be great to have a small version like the Kragen in my tool box at the track. What I can't tell from the web site is if you can reset codes. Do you know? I tend to set off my check engine light fairly often and need to reset it at the track.
Jim
Is there another make that someone has used effectively? I had the obd-II one and it made my laptop crash over and over enough that I sent it back. thanks.
