I'm not sure about whether the steps are exactly the same. Here's another post for a 944 if that helps.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/288809-944-alternator-replacement-photos.html
Assuming your multimeter is accurate, your readings point to a bad alternator. You can take the alternator to an auto parts store for testing to confirm. It could be the regulator and/or diodes inside the alternator. The shop should be able to pinpoint that.
UPDATE...i had my alternator reconditioned.  The guy confirmed it was overcharging.  Put new regulator in and cleaned it up.  I reinstalled and fired her up.  All the lights are perfect now.  No pulsing.  Problem solved!  Thanks everybody.
Roch
