I am thinking of installing a wideband air fuel sensor gauge. Is installation similar to narrow band O2 sensors in which there is a signal wire that can be spliced into the OEM sensors to get a reading on the air fuel gauge, or does it require installing a separate wideband O2 sensor.
Quote
From what i have been able to find out, the front O2 sensors are wideband and the post cat sensors are narrow band
Good to know.  I'd think then you'd be able to tap into the output of the front sensors for your AFM meter.
If I did tap into the stock we ideband harness, would I not tap the heater lines so that an aftermarket system would not cause problems with the stock system
