hi,
my 996 '02 targa comes with the std. shocks/springs.
the car looks to be in offroad mode, if you drive it is not too soft. in fast corners the car goes over the front end...
now i am thinking about changing only the springs to H&R, Manthey or Eibach (by using the old shocks).
have you any experience how the car will drive with this springs on the street and on the track?
thanks
Yes....AND....NO, don't bother. They're usually a match made in hell. Go with the complete magilla....Bilstein setup, no questions about it. Mark
I tried the Cargraphic (made by H&R, supposedly a bit softer than regular H&R's ?) springs with stock shocks and the shocks did not work correctly, the car would bounce a couple of times after a big enough bump. I then switched the stock shocks to Bilsten sport struts and the ride is just right. Mildly more stiff and firm but not to rough.
