Hi Everyone,
My 1999 C4 has 2 CEL appearing P1397 and P1341
I took the car to my indy and had him work on it.
I knew it would cost a lot of money and would take a bunch of time, but i just wanted it fixed.
He kept the Car for quite a while, changed a bunch of parts (please see attachment), ie: Camshaft sensors, R.S Actuator solenoid..etc
Put the car back together, and still the same codes still rough idle.  At this point I have the car back, only paid him for parts, he has no idea what to do
Ive read a lot of threads, but have no idea what it can be at this point.
Please help
thanks
Derrick
The P1397 code is common when the cam position sensor on bank 2 has in implausible signal, often caused by it simply being disconnected or lacking power.  I think your other code is actually P0341, which is the same thing but on the other bank.
Thank you for the response, Are the Cam position sensors something i can get easily, or if not easily without removing the engine?
You should be able to get at them without much fuss.  Do a quick search, there have been several threads pertaining to checking and replacing these sensors that should be helpful.
