I have a 2003 Porsche Cayenne S without a CD Changer. In the side panel is a power connection but no fiber optical connector.  I purchased a CDC-4 and plugged the power connector and have power to the unit.  Question is if I purchase an optical waveguide cd changer to booster cable (955 642 304 00) can I unplug the optical ones I see going into the amplifier above the CDC bracket and plug the CDC-4 into the loop somehow?  Any advice would greatly be appreciated.
The cable or cables you need will depend on the options your car has (i.e. radio or PCM, amp or no amp, cd-changer or no cd changer, telephone or no telephone).
Programming may or may not be required.
So which options do you have?
I have the CDR-23, bose, amp, no phone, no CD changer except for the single slot built into the CDR-23 in the dash.  Thank you.
Thank you for the diagram.  I bought the CDC-4 from ebay and it did not have a kit with it. Behind the passenger side rear compartment I have the amplifier and CD holder already in place.  Looks like I need to purchase items M, N, H and K from the diagram and figure out how to wire the CDC-4 to the amp.
I phoned the local Porsche dealership to inquire about the Optical Waveguide and provided them with the information on what currently existed in the car. I told them I had the CDR-23 in the dash and the amp (bose system) in the back side compartment. I told them everything was back there (bracket, power) except gor the CDC-4. I told them I had the CDC-4 that I purchased from another source.  The parts salesman said I needed an optical waveguide and a connector. I told him I should just be able to take the optial waveguide and connect it to the amp above the CDC and then run it to the CDC.  He said that I had to remove the side panel and passenger seat to run an optical cable from the rear compartment to the CDR-24 radio in the front dash.  Does this sound correct?
Thank you.
