2007 C4S with Tip and 58,000 miles
My CEL came on yesterday, due to codes 2187/2189. After a brief search on the internet,  loose oil/gas caps came up as possible causes. So I cleared the codes and tightened the caps, but the CEL came back a few  hours later.
I also just noticed last night that, when idling in Park, it revs at ~1,100. In Drive with the break on and the car not moving (no pressure on the gas pedal) the idle revs drop to normal (around 700-800). Also the idle is a little rough. Any ideas what causes this? Thank you all.
I would have thought the revs drop between D and P was normal. P = no load D = torque converter ready to go? Also when in park it will be in open loop mode whilst in D it will be in closed loop with idle controlled by ECU etc. (Leastways that's the way I understand it to be?) initial high idle possibly due to an induction leak?
Edited by jl-c
Before this happened, the idle in P was around 750-800. This behavior (P idle ~1,110) is new, and, I believe, abnormal.
Edited by Koenbro
typo
The codes indicate the engine is running lean. It would help if you could monitor the RKAT fuel trim with durametric or the short term fuel trim with a generic obdii scanner that can read sensor values in real-time.
Without those, you can check for intake vacuum leak like jl-c said. The engine is always in closed loop fuel control other than the short period at the very beginning of a cold start, regardless of the gear position. The DME watches the a/f ratio like a hawk so it makes sense to trust it and diagnose along that "lean condition" direction - too much air or too little fuel.
RKAT is stable at 6.984 for both banks. Just noticed that when in D and stopped, and want to get rolling and just feather the gas it sounds loud and rough (like a 1980's diesel) until the revs reach ~1,100, then it quiets down.
Edited by Koenbro
Dealer said a rubber sleeve leading to the intake came loose. They tightened it and that resolved the problem.
Edited by Koenbro
