Guys,
I have a 2001 996TT with 100.000km/~60.000miles.
Last week I had a P1358 without any strange behavior. I cleared it and the next morning it stuttered a bit in 2nd gear when leaving the house, without throwing any errors. I returned immediately and started studying all the possible posts related to Camshaft Adjustment Errors (P1358, P1357, P1348, P1349 etc…).
My angular values are as follows:
Cold
Idle: ~850rpm
Camshaft position 1 deviation: -3 degCrk
Camshaft position 2 deviation: -5.2 degCrk
Actual angle for camshaft, bank1: ~0.06 degCrk
Actual angle for camshaft, bank2: ~0.15 degCrk
Warm
Idle: ~850rpm
Camshaft position 1 deviation: -2 degCrk
Camshaft position 2 deviation: -4.8 degCrk
This morning I disconnected the (when in the car right hand bank, assuming #2) bank #2 solenoid or as called in the parts list “actuator valve” item#25 996.105.301.71. Expecting to get a P1358, instead I got P0022 and disconnecting item#23 I received P0023.
Not yet being able to reproduce it and reading about 0-6deg allowable range, my best hope is that the error (& stuttering the day after) was dirt?? and plan to do an oil & filter change, even though I’ve only done 2000-3000km (~1500miles). I’ll examine the oil-filter for any particles and will post the result.
Now to my questions….
Is there anything I can simulate to trigger the P1358 and better understand where it comes from ?
What would you suggest I do, without taking too much apart ?
Thanks in advance
Regards
Arnaud
  • 8 months later...
Sorry to revive this topic but I am having the same issue.  But I found some metal when I pulled my actuator.  I'm praying I don't need a new motor.  Has anyone solved this issue?
That is not good.  These engines can shed aluminum without a lot of concern, but ferrous debris is a sign of something more serious.  I would not be driving a turbo around that has ferrous debris in the engine as that Mezger lump is a bloody expensive unit to replace.  You need to find the source of this ferrous material and fix it before it tears up something very expensive.
