Loren -- I've seen your write up (below) on removing/installing a 996 glove compartment to replace the microswitch. I assume given the similarity of the cars that this will be the same procedure for a 2003, US spec 986S. Can you share the part number of the harness section that contains the microswitch?
Thanks. Carlos
