http://www.geocities.com/pcarsound/
(Edit: Changed file location to geocities - limited bandwidth)
Been narrowing this down over the past couple weeks.
The car is a 2001 C2, 6 speed.
The noise seems to occur when restarting the car after it's been driven, then parked for 15-20 minutes. As such, the sound usually occurs when I'm backing out, and it seems to occur more often than not just as I start to turn the wheel, but has occured once while just sitting in a parking space.
The link above is an .mp3 of my car being backed out of the garage. The sound occurs at 0:15 just as I started angling into my driveway. The sound also occurs at the very end of the file, just after I turn the car off (never did that except this one time).
The car is going in on Wednesday, but I'm sure it'll decide to behave then.
btw...it's a poorly recorded, highly compressed .mp3. :)
Edited by Random Alias
The sounds are so mixed it is hard to tell if something is loose and rubbing or if you have a serious air leak in the crankcase, exhaust, or intake... best let a mechanic hear it in person. I personally would not drive or run the car any more until it is solved... (JMHO)
Yeah, that one had a lot of compression artifacts.
I cleared up some space and here's the same sound with much less compression.
If you have a broadband connection it'll be small enough, but dial-up won't be worth the bother as there is still a lot of ambient noise.
1.2mb file.
Okay...good news? I finally got my wife to stand outside the car and listen while it happened. She swears the noise is definitely from the front of the car.
I believe they determined it was an expansion valve in the AC system that needed to be replaced...or something with the AC system. The didn't have the part in stock.
I have the same sound when the AC has been on and it is hot outside. I read somewhere on rennlist that this is caused by a release valve in the AC system. Others on rennlist have complained of the same sound. If there is a fix I would be interested.
Jeff
Just had the car in and here is what was done as per the invoice:
Expansion Valve Removed + Reinstalled
996-573-929-01 EXPANSION VALVE
Can't say for sure that this fixed the problem as it was intermittent, but so far so good.
