I had the water pump replaced a year ago but just noticed the hose encircled in red (attached photo)  doesn't look very good.  I'm planning on replacing it as soon as the part arrives.  How much coolant should i prepare to lose when I remove the hose?  Thanks in advance.
Since the hose is very close to the bottom of the engine block so it's practically at the same level as the coolant drain plug. I would say expect 2~2.5gal coming out if you don't plug up the opening at the flange. The top part of that hose goes to the TOP of the heater core so it won't have much coming out (other than the coolant that's inside the hose/metal pipe).
