Hi all, just moved over from the Boxster forum, had 8 great years with the Boxster looking forward to similar with the 997. Obviously been going through the car with a fine tooth comb and looks to be good. I have one small issue with the center air vents, the adjuster will move the flaps up and down but there doesn't seem to be any connection to the flaps for lateral movement in both vents.Something is missing or broken. How easy is it to remove this air vent module to have a closer look at whats going on.
