2002 Boxster S - headlights won't come on full bright. When I rotate the switch to on position, lights come on but very dim. High beams won't come on when the switch is pushed forward, but they will operate when pulled (i.e. flash to pass).
Any ideas out there on probable cause and how to troubleshoot?
Just throwing this out.  Make sure your headlights are seated properly.  My driver side had a cracked mount and just removed it from that and seated it directly into the socket.
