have a few codes that came up, gee what a suprise,ordered 4 new metal ignition coils, but have p1525 code, o2 sensor? front or rear?
po354 coil voltage ?
p1525-o2 gas cap?
po 441-purge valve?
any help thanks
P0354 Bar ignition module on cylinder 4
Possible cause of fault
The wiring might contain the following faults:
- Open circuit in signal wire
- Short circuit to B+ in signal wire
- Short circuit to ground in signal wire
- Short circuit to B+ in ground lead
- Open circuit in ground lead
- Open circuit in power supply line
- Short circuit to ground in power supply line
- Incorrect assignment of ground lead and positive lead
Following components can be affected:
- Bar ignition module faulty
- DME control module faulty
9 times out of 10 the coil is cracked and needs to be replaced.
P0441 Fuel tank ventilation system above limit value/below limit value
- Tank vent faulty (remains stuck in an open or closed position)
- Tank vent installed the wrong way round
- Leak in scavenging lines between tank vent and positive crankcase ventilation (in the Turbo via a T-piece also on the intake side of the turbocharger)
- Scavenging lines between tank vent and positive crankcase ventilation trapped or blocked (in the Turbo via a T-piece also on the intake side of the turbocharger
P1525 Vehicle Electrical System Voltage via Main Relay - Signal Implausible/Open Circuit
- Contact resistance or open circuit
