ok so  i changed the steering angle sensor went through the calibration process using autologic scanner. sensor is working properlly. the problem i am having not is that i am getting a p1276 hydraulic pump not working only got this after changing sensor
Fault code 1276 -- Hydraulic pump
Possible cause of fault:
- Plug connection to PSM control module is corroded or damaged (faulty plug connection)
- Hydraulic pump (faulty)
