I have. 2008 Turbo Cab Tip , I just purchased this Porsche . The 1st thing on my list was to hook up my battery tender to my battery
I checked the fluid level and had to add approx 50cc of distilled water to each cell.I filled the cells up to the 1st ring , maybe a bit to much
fluid ! The release hose on the side of the battery is hooked up and intact . When I backed out of the garage I left a 15ft thin watery trail
of battery acid ( I tasted it - bitter ) Where does the weep tube exit and I want to make sure there is no battery acid damage Thanks Elliot
It exits directly below the battery tray area, beneath the car.  You can also disconnect the vent line and run some clear water through it as well.
