I have had my '97 Boxster parked for around 6 months. I fought through replacing the alternator to now replacing the water pump and thermostat due to the recommendations of pelican parts. I now have an electrical buzzing when turning the key to the on position. After starting it stops buzzing. Is this something with the immobilizer possibly or an error code that needs cleared? I am currently waiting to finish the water pump replacement and thermostat due to being an American on the 4th of July. Also when up on jacks it appears coolant has shot onto every surface at the rear of where the plastic under cover should be where the little rubber vent flaps are. Any advice other than replace those parts and see if the leak occurs again would be greatly appreciated. The electrical buzzing concerns me greatly though.
