The coolant temperature warning light on my 2002 Boxster S Tiptronic is flashing. It flashed when I started the car, so the engine was still cold. I checked the coolant level and I was at maximum. The manual says to turn off the car immediately and bring it to a dealer.
Is this something that I want to flatbed the car to my local Porsche mechanic or can I drive the car to the shop (about 5 miles away)?
Also, any ideas what might be going on?
Depends on how it is flashing:
Four functions of the coolant warning light:
1. Engine coolant level too low
  - light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high
  - light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high
  - light is lit; pointer on the right
4. Temperature sensor at water outlet faulty
  - light flashes rapidly (1 Hz); pointer on the right
Note
The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously
(1Hz = 1 flash per second.  0.5Hz = 2 seconds per flash)
