I wanted to flash my 996 C2 (MY2000, eGas), once I had finished some small upgrades (Bypass, gt3 throttle body, IPD plenum & BMC air filter) and was suggested not to.
The attached dyno chart, showed ~25 hp were missing and second half of the chart has little less torque than expected. It didn't look a big deal to me:
Anyway the tuner found too lean mixture at the higher end (above 6000 rpm) so he recommended me to find out the reason before going any further. Since he is not a Porsche specialist he could not help much and thought about a weak fuel pump...
Anyway I'm not that sure about it. As I have a durametric cable I've done a couple logs and here is what I got on a 3th gear WOT launch:
1-RPM
2-Mass air flow (MAF)
3-Adaption, range 2 (FRA), bank 1
4-Adaption, range 1 (RKAT), bank 1
5-O2 sensor voltage ahead of cat. conv., bank 1
6-Adaption, range 2 (FRA), bank 2
7-Adaption, range 1 (RKAT), bank 2
8-O2 sensor voltage ahead of cat. conv., bank 2
   1             2       3       4           5     6          7            8
1.681     160    1,02    -0,19    0,84    1    -0,52    0,87
1.928     188    1,02    -0,19    0,88    1    -0,52    0,88
2.176     221    1,02    -0,19    0,86    1    -0,52    0,87
2.418     237    1,02    -0,19    0,88    1    -0,52    0,88
2.673     244    1    -0,19    0,88    1    -0,52    0,89
2.921     295    1    -0,19    0,88    1    -0,52    0,87
3.156     323    1    -0,19    0,87    1    -0,52    0,86
3.400    342    1    -0,19    0,88    1    -0,52    0,88
3.679    390    1    -0,19    0,87    1    -0,52    0,87
3.985     437    1    -0,19    0,87    1    -0,52    0,88
4.253     468    1    -0,19    0,87    1    -0,52    0,87
4.539     516    1    -0,19    0,87    1    -0,52    0,86
4.816     561    1    -0,19    0,86    1    -0,52    0,86
5.104     589    1    -0,19    0,85    1    -0,52    0,85
5.424    624    1    -0,19    0,84    1    -0,52    0,84
5.697    667    1    -0,19    0,84    1    -0,52    0,83
5.988    695    1    -0,19    0,83    1    -0,52    0,83
6.286    680    1    -0,19    0,81    1    -0,52    0,81
6.565    704    1    -0,19    0,81    1    -0,52    0,76
6.857    764    1    -0,19    0,83    1    -0,52    0,82
7.056    784    1    -0,19    0,85    1    -0,52    0,83
7.306    643    1    -0,19    0,84    1    -0,52    0,81
Cleaned MAF and checked for leakages already.
I'm pretty lost here.... Need a new MAF, O2 sensors, check hidden leakages???
Any suggestions will be wellcome.
post-103485-0-82137200-1467010616_thumb.
Edited by Xabiitxu
