Hi
My pedal is notchy at the top end.
Have changed, slave (due to fluid in boot) accumulator, master, power Spring.
Had a new sachs clutch, fork etc. Seemed to start after the new slave install.
Have bled the system many times, even used a pressure system.
Has anyone had the same problem., help!
Edited by kamc
Sounds like you may have a clutch fork pivot issue.
Hi
Thanks for the reply.
Had installed a new fork, shaft bearings etc.
Installed a new steering pump resovior as I have heard it has a pressure valve.
Pump tested all fine.
Did a overnight pressure test, no leaks needle did not move.
So frustrated!
Edited by kamc
