So I've read the other posts on blinker issues, but this seems odd.  My blinker inside the front headlight is not flashing.  Driver side/ left turn is.  When operating blinker and looking at dash the left turn flashes too fast and right turn flashes normal.  Hazards work except for that passenger side front blinker light. Headlight or relay problem?  Ideas?
Now that we have gotten past that one, check your bulbs on the side blinking fast to be sure they are illuminating properly (could be a bad bulb), otherwise I would look at the turn signal flasher module, it may be going south.
part # on the fluid?  :cursing:
j/k but seriously, does anyone know the part # on the relay?  parts guy just told me he only finds an emergency flashers relays- not sure its the same...
Call board sponsor Sunset Porsche in Beaverton OR; they should be able to help you.
