There's an occasional groaning sound coming from the front passenger wheel well. I think it's the suspension because when I pushed down on the fender the car emits a groan sounding. Is it the shock absorber or maybe the sway bar? Do I need to bring it to the dealer? I was wondered what you guys thought it might be. Thanks in advance.
Pat
Have them check the swaybar to see if it is loose (fairly common). They should check the strut too - fairly rare but I have seen a couple loose or bad struts.
I went to the dealer today. They ended up replacing both lower control arms under warranty. Saved me $1,500. Nice!
