Cheap fix for annoying exhaust rattle
This is most probably caused by your heat shields over the catalytic converters. They get rusty and the fixings cannot work properly. I was surprised how much the heat shields (£84 for two) and then the fixings cost (£30 for two sets) so I decided to try a DIY fix. So far this has worked perfectly!   You may find that the heat shields look like this:   You may have some good holes/fixings left but some rusted holes and no fixings.   I used some aluminium sheet which I cut in a square
