All lights work correctly except the driver DRL doesn't work. I have replaced the bulb and still nothing.
Question...could the double relay be the cause?  I assumed if the relay were bad that both DRL wouldn't work so I haven't replaced it yet. But after reading comments I began thinking the possibility of just one portion of the relay could be faulty if it's a double relay.
I worry that the issue could be contained in the headlight housing, although when I replaced the bulb the housing looked almost untouched.
Has anyone ran into this issue??
The relay has separate contacts for left and right side lights so it's possible your relay is the culprit. You can remove it and bench test it. I know someone actually opened It up and fixed the bad contacts inside.
Ahsai, thank you for the response.
OK, that's actually great news!! I will remove and bench test tonight and let you know my findings!!
Ok, so I looked for the relay in position 6 and 7 and there are no relays there and whats worse is there is no electrical connection in those spots, just to empty slots with nothing behind them.  Am I correct in assuming that means that the headlight assembly was purchased to replace the non-HID headlights that could have come with the car? If so that leads me to believe the issue is in the headlight housing.
DRL was an option in MY2001.
Does your car have option code M113?
If you do not have your car's option codes PM me your VIN and I will look it up. for you.
