P0107 says there is a problem with the MAP sensor (manifold absolute pressure), I called the dealer and they say that the Boxster doesn't have one???
Is there a different German name for it?
This car barely runs.
Time to find a dealer that knows...
P0107 Ambient Pressure Sensor – Below Limit
Possible causes:
- Short circuit to ground
The ambient pressure sensor measures the air pressure.
The ambient pressure sensor is incorporated in the DME control module.
I would clear it and see if it comes back.
