Hello,
This is a 1999 Boxster. I noticed that one wire on the wiring harness of the engine side o2 sensor is
broken.
I tried to find the wiring harness from the web and couldn't find anything.
The wiring harness has the number 1-965 261-1 on it.
It has 4 wires which are connected to the engine.
The other side of the harness is connected to the o2 sensor connector.
Is there anyway to repair the harness? Can I splice the wires and connect all 4 wires
directly bypassing the connector?
Thanks.
Steve
Porsche sells a repair kit for around $120 - much better than a new harness at about $1500.
You will need to give the dealer your VIN to get the correct repair kit.
