2006 Cayenne S.
I've just experienced the lights of the steering wheel going dead a few moments after turning on the headlights.  After turning off the car and re-starting, the same problem occurs (lights come on with headlights initially but then shut off).  The two on/off buttons behind the steering wheel have no effect after the lights go dead (but do work when the steering wheel lights are functioning).  Short somewhere?  Any thoughts please?
Thank you
  • 6 months later...
If this helps anyone else... the battery died last month and after a new battery was installed, this problem has rectified itself.  This may indeed be another low battery symptom.
