I'm in the process of installing a solar powered battery maintainer. The goal would be to wire a NC relay to the solar panel output. In order to energize this relay, I would like to tie it to something that was 'on' when the engine was running. I would prefer a location in a box like the fuse-box. I do know where the phone jack is under the e-brake and would prefer not to use that (I have other plans for that power...). I've looked through the fuse sections of the schematics and can't tell what I should tap off of, or if there is a spare someplace. Any help is appreciated.   Regards, Vic
