Boxster 987 Wind screen rattle
Take a close look at the clips and mount holding the screen in place.  You will see that one is made of rubber and that there is a small cavity that over time when the rubber ages loose some pliability.  Take a sponge that has a scrubber side and rip off some of the stiff scrubber side off the sponge (you will need very little).  Stuff a very small amount of the scrubber sponge material into the cavity of the rubber mount.  No more rattle.  FREE AND EASY!   (I was working from memory... I thin
