Hi all
I'm new to the forum, and have a common problem with my 4x4 system. I had it diagnosed today, and have ordered a new Transfer case ecu. My problem is, I don't know where it's located?? My car is right hand drive if that makes any difference??
Sent from my iPhone using Tapatalk
Hi all
Welcome to RennTech :welcome:
On North American cars, it is under the passenger's seat, so I'd look under your driver's side.
Hi all
Thanks. I'll take a look, you are probably right, as the battery is under the passenger seat on mine.
What symptoms / problem do you have with your transfer case?
Hi. I have a 4 x 4 fault on the dash, and no power to the low gear selector switch on the centre console (no red lights) resistance is also high on transfer case actuator. I've ordered a ecu and actuator from eBay (2005 spec.)
