955 Turbo Coolant Ts Tutorial DIY
ere is my 955 Cayenne Turbo Coolant Tees (or Ts) DIY Tutorial to help those tackle this in the future. First, you need to remove the intake manifold.  There are several DIYs on this.  It also helps to remove the secondary air injector pump on the driver side.  You will see why below.   You can remove the entire Tee assembly in one piece--only 4 points need to be unclamped.  I labeled these points A,B,C, and D.  All 4 points required me to razor the rubber hoses to remove them.  Cabl
