After replacing both soft top push rods (one was severely bent) I noticed the front edge of the clamshell was rubbing the soft top on the passenger side while closing.  I adjusted the passenger side pushrod to increase the clearance but there is still not much clearance on either side (less than the width of your finger).  How much should the minimum clearance be while closing the top?
