Gear shifting problems.
When I try to shift at high revs/torque the gears will not go in easy.
It feels like the clutch will not engage fully, you still have  torque/revs even if you have pressed the clutch pedal to the floor.
I've tried to bleed the clutch, couldn't see any air bubbles.
Are there any other adjustment possibilities?
Please do not double post, it is against forum rules.  Your duplicate post has been removed.
Your car has a hydraulically actuated clutch, there are no adjustments.  If the system has been correctly bled, and you still have problems getting the car into gear, you most likely have a clutch failure and need to pull the car apart to see what needs to be replaced.
