Found a very nice set of wheels....
Need to figure out if they are hollow spoke or solid and the sizes..
Seller really doesn't have an understanding of what I am looking for..
Here are the part numbers from the back of the wheels
99336213405
99336213800 also 9933621400A
So what is the verdict?
Edited by Docdanracy
993.362.134.05 18 inch Techno wheel -- 7.5" wide and 50 mm offset
993.362.138.00 18 inch Techno wheel for Boxster -- 9.0" wide and 50 mm offset
993.362.140.01 18 inch Techno wheel -- 10" wide and 65 mm offset
993.362.140.0A is not a good part number
You are correct Loren
Second number is 140.01
I assume on wheels with both of the second set of numbers is the 10" variety
I believe I had a set of those rear wheels on my '99 996..
Hollow spoke
