Hello gang,
I replaced a right rear tail light (the left one of the bottom two). I then swapped some of the other light bulbs (reverse, turn signal and brake lights) just to make sure they all worked. When I swapped the turn signal bulb. It lit up once then went dead. I then turn on the vehicle and got warning messages that said "check corner light" and "check right indicator light". So all this to say that ii have no right turn signals anymore and the tiny little bulb in the corner doesn't light anymore (the bulb is good though).
Any advice is appreciated.
Roch
Check your fuse - there is a fuse that handles those 3 lights - on my 2005 CTT I think it was #35 in the right side dash fusebox (10amp).
If it's blown you may want to check your headlight wire harness - see the picture of mine below which blew the fuse.
post-102552-0-70514300-1460429381_thumb.
That was it! I was told to check fuse 30 and that was fine. So I was stumped. 35 it was! Thank you so much.
Roch
