Hello. I have a 1998 ROW coupe. I had a driver door lock that would jam when it was in the sun for a while. The window would drop, but the lock would not release. It would take several lock/unlock cycles before the lock would release. I just replaced the lock mechanism, and now, when you use the key in the door, it will not lock. The key fob can lock the door remotely, but the key in the door does nothing.
When I lock the door, I get a double flash of the turn signals, the dash LED double flashes for 10 sec then goes to slow flash. When I unlock, I get the turn signal flash but the alarm horn beeps twice. Is there something I need to do to reset the door lock? Is there a "learn" procedure I need to complete to get the key to work correctly again?
The connecting rod between the lock cylinder and the door lock mechanism is not connected properly or defective. You will have to start over, the connecting rod looks like a mini oar, the flat end of the rod falls into a groove of the door lock. Since the remote controle turns itself off after about six days, this is a problem whitch must be solved as soon as possible.
+1 to what RFM has suggested.
Ensure that you lock and unlock the car with remote before it goes into sleep mode after 5 days(?)
Edited by wizard
At least it saves you a trip to Behbehani :-)
That's no kidding! Those guys are SLOW! Anyways, Pulled the door off, got the lock lever back in place and all is good. Also figured out that the "fits 996 and 986" door locks actually don't work on my 1998 model. The electrical portion would not activate correctly, thus the double beep when unlocking. I swapped the electrical part and used the newer mechanical part. Now it works perfectly.
Thanks!!
